expose list attribute as feature
  • January 7, 2019
  • 16 views
boubcher
Forum|alt.badge.img+11
Hello there 'I am reading a XML file , and looking to expose the hidden attribute
as you can see in the Pic
I tried attribute expose and list exploder but it didn't work
  • January 7, 2019
How did you configure the AttributeExposer? You will have to expose the following attributes:
FieldInfos.SubtypeFieldInfo{}.DefaultValue
FieldInfos.SubtypeFieldInfo{}.DefaultValue.pos
FieldInfos.SubtypeFieldInfo{}.DefaultValue.type
FieldInfos.SubtypeFieldInfo{}.DomainName
FieldInfos.SubtypeFieldInfo{}.DomainName.pos
FieldInfos.SubtypeFieldInfo{}.FieldName
FieldInfos.SubtypeFieldInfo{}.FieldName.pos
FieldInfos.SubtypeFieldInfo{}.pos
FieldInfos.SubtypeFieldInfo{}.type
The ListExploder should then let you select the list "FieldInfos.SubtypeFieldInfo{}".
Notice that there are no numbers in the {} brackets.
