Expand regex editor to AttributeTrimmer
p_c_20
Forum|alt.badge.img+8
Would be great if Regex Editor and AI assist was added into AttributeTrimmer rather than having to use the Regex functions in text editor, which are clunkier. In fact, it could go in any and all string transformers where you are trying to identify, use or replace a substring.
alexbiz
Forum|alt.badge.img+14
  • June 23, 2025
AttributeTrimmer only remove leading and trailing characters of an attribute.
https://docs.safe.com/fme/html/FME-Form-Documentation/FME-Transformers/Transformers/attributetrimmer.htm
It would be weird to use regex here.
You might want to use the StringReplacer instead, which can use regex and replace with no character.
p_c_20
  • June 23, 2025
How about if I want to left trim [^\w] down to nothing?
alexbiz
  • June 23, 2025
p_c_20
  • June 23, 2025
alexbiz wrote:
Yes, but left/right trim, not replacing in the middle of a string (which is what this would do, right?)
alexbiz
  • June 23, 2025
^ mean the start of the string
$ mean the end of the string
^\w* litteraly translate to “all word characters (from 0 to x) at the beginning of the string”
alexbiz
  • June 23, 2025
So this is a left trim, it will not replace value in the middle of your value
p_c_20
  • June 23, 2025
Ah. Many thanks
