Exclude a folder in tester
  • Oct 21, 2022 2:08 PM UTC
  • 55 views
hugues
Hi. I use a tester. It's with path extractor. The tester have a fonction to exclude some folder. I need to exclude all the folder with name include "0_".
The floder containt path with "0_" are exclude.
I need help to have the right expression to select all the folder with "0_" in the path name. Thank
exlcusiontester
dustin
Forum|alt.badge.img+36
  • Oct 21, 2022 3:16 PM UTC
You are very close. You need only one clause in your tester, and that would be NOT path_director_unix contains 0_
