Excel FeatureWriter ignoring Row Number Attribute
  • Aug 2, 2022 3:48 PM UTC
  • 230 views
Hi all,
I've published a workspace to FME Server which updates some rows in Excel. When run on FME Workbench, the rows are correctly updating (using fme_db_operation = UPDATE) at the correct row number, which starts at row 10. I've set the row number by using a counter for xlsx_row_id with a Count Start set to 10.
Weirdly, when published to FME Server, the workspace ignores the xlsx_row_id attribute and starts writing at row number 1 (even though it gets the correct column positions). Is this a bug in FME Server? Does anyone have a workaround? I've tried different options in the Start Position parameters of the FeatureWriter (both "Named Range Start Row" and "Start Row") but no success...
Any advice gladly received,
BI
FeatureWriter parameters
  • Aug 2, 2022 3:54 PM UTC
I've just found the answer, the counter that generates the  xlsx_row_id needs to be set to Local rather than Global on Server.
@bi​ There should be no difference between FME Desktop and FME Server, the underlying processing engine is the same, provided the version of FME Desktop and FME Server are the same.
  • check and confirm that the versions of FME Desktop and FME Server are the same
  • check how the xlsx_row_id is being set. Perhaps the FME Server is being passed the wrong value
  • Aug 2, 2022 4:17 PM UTC
thanks, Mark, it turns out that the Counter needed setting to Local rather than Global. All working once I changed that.
