Excel Data Help
  • Jun 16, 2016 10:06 PM UTC
  • 50 views
Hello All,
I am trying to get rid all data (in the writer) except the first row (Pullin) and last row (Pickup) of each run (Only the Yellow Highlighted Rows). Is there any FMe transformer that can trim data? Please advise. I would appreciate the help.
Best answer by takashi
Hi @gsgoraya, I think you can test these conditions with a Tester (Pass Criteria: One Test (OR)) to determine whether a row should be kept.
  1. The 'Pull In' field in the row has a value.
  2. The 'Drop off' field in the NEXT row is empty (or missing).
It's easy to test the 1st condition. Regarding the 2nd condition, you can retrieve the value of 'Drop off' in the NEXT row with the AttributeCreator using the 'Enable Adjacent Feature Attributes' option (Number of Subsequent features: 1) before testing. e.g.
You can then test whether the '_next_Drop_off' has a value, in the following Tester.
  • Jun 17, 2016 2:33 AM UTC
  • Jun 17, 2016 3:26 PM UTC
Hello Takashi,
Thank you for answering. I tried but it does not work for me. Can you please provide detailed instructions if you don't mind. I would appreciate.
Goraya
  • Jun 17, 2016 5:51 PM UTC
Thank you Takashi for your help.
Gurpreet
