Escaped Characters (">" and "<") Appearing in XML When Using xmlUpdater
  • August 22, 2025
  • 87 views
francisco_1988
Forum|alt.badge.img+5
Guys, I need some help with my XML. In some parts of my document, characters like "&gt" and "&lt" appear. Specifically inside the <data_dictionary></data_dictionary> tag, where I perform an update using the xmlUpdater transformer. What could be causing this?
Best answer by takashi
Hi ​@francisco_1988 ,
If you intend to replace the contents of the target element with XML contents stored in a feature attribute, you will have to set "XML/XQuery" to the Value Type column and use the "fme:get-xml-attribute" function in the Value column to get the attribute value in order to treat it as an XML fragment, not a string value. See the XMLUpdater Help to learn more.
  • August 23, 2025
francisco_1988
  • August 23, 2025
Olá@francisco_1988 ,
Se você pretende substituir o conteúdo do elemento de destino por conteúdo XML armazenado em um atributo de recurso, será necessário definir "XML/XQuery" na coluna Tipo de Valor e usar a função "fme:get-xml-attribute" na coluna Valor para obter o valor do atributo e tratá-lo como um fragmento XML, não como um valor de string. Consulte a Ajuda do XMLUpdater para saber mais.
Thank you sr. Takashi!
