Error reading DGN files from Projectwise
mickd
Hi.
I have a workspace that is using the Micostation DGN (v8) reader that's reading files from a Projectwise URL collection. It's currently reading four dgn files successfully however when trying to add other I'm getting an error message.
  1. Failed to obtain any schemas from reader 'IGDS' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
  2. Workspace generation failed. Parameter file was C:\\Users\\{USER}\\AppData\\Local\\Temp\\FME_1701131211957_17128
I've tried opening the files in a clean workspace and even rebooted my machine to rule that out. The same message persists.
Within the reader I'm "Grouping Elements By Scheme - Level Names"
and selecting "Preserved Names Cell Insert Points". I also assign a coordinate system to the dataset.
Are there any suggestions about how I can overcome this, or will I need to go and have a chat to our CAD guys?
Thanks,
Michael
  • November 28, 2023
What happens if you try using the ProjectWiseWSGConnector to download the DGN file before reading it using the FeatureReader?
mickd
  • November 29, 2023
Hi David.
I can successfully download using the ProjectwiseWSGConnector the file, however when using a FeatureReader on the downloaded the file it returns the same message.
  • Failed to obtain any schemas from reader 'DGNV8' from 1 datasets. This may be due to invalid datasets or format accessibility issues due to licensing, dependencies, or module loading. See logfile for more information
I'm not experienced with Microstation data so this is a new one for me.
Looks like I'll need to chat with our CAD folks to see if there's anything they can interpret from the error message.
Thanks for the suggestion.
Michael
