Error executing string `import urllib
  • Jun 19, 2015 6:55 AM UTC
  • 94 views
I have an FME workspace that includes a Python start-up script used to download some zip files from a website:
import urllib
# Get Mining tenement zip files.
urllib.urlretrieve ("http://geodownloads.dmp.wa.gov.au/datacentre/download/mineral_inf/tenements.zip", save_path + "tenements.zip")
The script works fine in FME Desktop, but fails when run by FME Server with the error:
Any ideas what the problem could be?
Thanks
Dave LL
Best answer by david_r
Hi
urllib is part of the Python standard library, I would be surprised if that was the problem. I suspect something else is the problem. A frequent issue is by default FME Server has no rights on the local network shares, could that be the issue here? Also, have you verified that the FME Server machine has internet access?
What is the complete error in the FME log?
David
  • Jun 19, 2015 7:04 AM UTC
Hi
David
  • Jun 19, 2015 7:23 AM UTC
Thanks for the quick reply! Actually, your reply clued me in on the problem - local network shares. Resolved.
Thanks for you help.
Dave LL
