Writing to an Esri Geodatabase (File Geodb Open API) fails with this error: ‘Geodatabase Error (-2147219115): The row contains a bad value.
There's an empty table created instead of a point layer.
The error suggests that something's wrong with the schema, but I can't find the cause. The issue stays even with only one feature and limited number of attributes.
Writing the result to a shapefile or to SQL works fine.
FME version is 2022.1
Anybody had similar issues with the Esri Geodatabase (File Geodb Open API) writer and knows how to solve this?
Thanks,
Ruth
