EPSG code not included in the list.
  • Jun 15, 2020 7:22 AM UTC
  • 112 views
I can't find an EPSG code (4083) in the "source coordinate system" list, in the Reprojector Transformer. Is there any way to load it? My FME version is 2018.1
Thanks!
  • Jun 15, 2020 7:28 AM UTC
You can add custom coordinate systems, see https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Coordinate_Systems/Workbench/coordinate_sys_custom_about.htm
If you know the ESRI projection WKT, you can use this tool to automatically create all the necessary configuration files for FME: https://demos-safe-software.fmecloud.com/fmedatastreaming/Coordsys/Start.fmw
There's also a lot of useful information here, inluding the ESRI WKT for EPSG:4083: https://epsg.io/4083
Hi, I have used the WKT, but there is the "hemisphere" projection parameter, and I don't know what to put in there. It allows every numeric possible value.
daveatsafe
Forum|alt.badge.img+24
  • Jun 23, 2020 4:08 PM UTC
Hi @juanrodriguezso,
You can use any negative number for the southern hemisphere, and any explicitly positive number (ie, +1 instead of 1) for the northern hemisphere. For simplicity, I would recommend using -1 or +1.
