Emailer Transformer : Fail with [Errno 11001] getaddrinfo failed
  • May 22, 2024 7:59 AM UTC
  • 1498 views
fred.haan
 Hello,
I use FME Forms 2024 and I have a very basic workbench just to test the emailer transformer and the configuration of our email system.
The Emailer is the following version
When I run I have this error and it fails:
<class 'socket.gaierror'>: [Errno 11001] getaddrinfo failed
Any Idea ?
Is it a probleme of mail smtp mail server accessibility. What is the configuration to adapt ?
Regards
Fred
hkingsbury
Forum|alt.badge.img+73
  • May 22, 2024 8:13 PM UTC
This thread here suggests it is to do with being unable to resolve the host name (likely of the SMTP server), have you tried with an IP?
https://stackoverflow.com/questions/7334199/getaddrinfo-failed-what-does-that-mean
If you have Flow, I would strongly recommend you looking to use a Topic and email Subscription in Flow. It centralizes all your email configuration, so in the event of you needing to change passwords etc, you can change it in one location and not have to search through and update multiple workspaces.
emsliealex
Participant
Forum|alt.badge.img+4
  • Participant
  • Oct 30, 2025 4:41 AM UTC
I got this same error. Pinged the email host and got no errors. Obiously returned the IP. Put the IP in as the host and worked fine.
