Edit legend output from HTMLReportGenerator
  • Sep 5, 2017 2:54 PM UTC
  • 6 replies
  • 79 views
barrett_h
Forum|alt.badge.img+5
Hi all,
Does anyone know if it is possible to hack the code used to generate the legend of a chart created by HTMLReportGenerator?
The attached image shows how cramped the legend becomes when there is more than a couple of words used in the description. I have tried to edit the bootstrap classes used by the appropriate div but without success. I don't know bootstrap well so I'm not sure if this is even possible. Any pointers would be appreciated!
  • Sep 5, 2017 4:07 PM UTC
Could using the ChartGenerator to generate the chart as a raster first then inserting it into the HTMLReportGenerator be a solution?
That way you could also use direct rather than indirect legends:
Source: https://www.goodly.co.in/8-best-chart-formatting-practices/
barrett_h
  • Sep 5, 2017 10:43 PM UTC
Thanks for the suggestion David, that really worked well. Hopefully in the future the HTMLReportGenerator will be further customisable as it is an awesome transformer and I do miss the animation of the pie chart :). Thanks again.
  • Sep 6, 2017 2:10 AM UTC
This seems to be a known issue on the HTMLReportGenerator, which I reported with C119382 last year and has been filed as PR#72076. The issue is more serious in Japanese characters. Every character is arranged vertically one-by-one, like this...
I want to use the HTMLReportGenerator in various scenarios, but cannot do it yet because of this issue. Hope this will be fixed as soon as possible.
Forum|alt.badge.img+54
  • Sep 6, 2017 9:07 AM UTC
You could try a string replacer with the following (I've not tested across all browsers but works for me in Chrome and IE)
  • Sep 6, 2017 9:37 AM UTC
Thanks for the workaround @egomm. Looks very good on Chrome,
but still is not ideal on IE for Japanese characters.
barrett_h
  • Sep 6, 2017 10:05 PM UTC
That's the kind of hack I thought might exist! That's a handy bit of code @egomm. The project is already out the door with the work around suggested by @david_r but I'll keep that for next time. Cheers.
