Dynamic schemas fails in "Redirect to FME Data Inspector" ?
  • Dec 11, 2019 8:37 AM UTC
  • 52 views
lifalin2016
Forum|alt.badge.img+42
Hi all.
I've been working with outputting data in dynamic schemas, and wanted to debug something using the Redirect to FME Data Inspector feature. This fails, showing "no schema" as the data's only attribute.
Is this WAD ? Shouldn't this feature work just as the proper output does ? Or does dynamic schemas only work in proper writers ? This make debugging somewhat more problematic.
Instead I cloned my writer, sending its output into a test folder, and that seemed to work as expected.
Cheers
  • Dec 11, 2019 8:56 AM UTC
Dynamic schema only works with proper writers, not with the Inspector, unfortunately.
lifalin2016
  • Dec 11, 2019 9:21 AM UTC
Thanks David. Sounds like an overdue implementation is needed. I posted it as an idea.
