Dynamic schema doesn't work with shapefile writer.
  • Sep 8, 2021 7:48 AM UTC
  • 6 replies
  • 118 views
davtorgh
Forum|alt.badge.img+12
Hi everyone,
I have set up a simple dynamic workspace that reads a shapefile, reproject coordinates and write a shapefile. This should be a general porpouse workspace indipendent of the source schema dataset, but the output dataset contains all the attributes of the input dataset plus the attributes of the dataset I used to develop the workspace (and I don't want them).
Could it be a bug of the shapefile writer? If I use a geopackage writer, instead, everything works fine.
Thanks.
muzhnasto
  • Sep 8, 2021 11:29 AM UTC
jdh
Forum|alt.badge.img+41
  • Sep 8, 2021 1:46 PM UTC
Could you share your workspace, or at least screenshot your writer feature settings.
davtorgh
  • Sep 8, 2021 3:02 PM UTC
Yes @jdh​ ,
here is a screenshot of the workspace.
Thanks.
jdh
  • Sep 8, 2021 3:09 PM UTC
Yes @jdh​ ,
Thanks.
On the User Attributes Tab, are there any attributes listed?
If there are, they will be added in addition to any dynamic attributes.
@davtorgh​ Follow the steps in the first section of the tutorial Dynamic Workflows. This should avoid the tangling of the dynamic attributes with the attributes from the original shape file that @jdh​ mentioned.
muzhnasto
  • Sep 8, 2021 5:54 PM UTC
you have dynamic FeatureReader ?
