DWG Writer - Dimension Text Rotation
  • Jan 15, 2024 1:50 PM UTC
  • 118 views
jasperwis
Forum|alt.badge.img+19
The documentation for autocad_dimension features says that you can use an attribute "autocad_text_rotation" to rotate the text of a dimension.
See autocad_dimension
However, I haven't succeeded in rotating the dimension text yet.
I use "autocad_dimension_type" = autocad_aligned
Any ideas?
danminneyatsaf
Forum|alt.badge.img+13
Hi @Jasper Wisbecq​, unfortunately I believe this is a known issue that has affected the AutoCAD format for some time now. The relevant ticket number for the issue is FMEENGINE-57826.
Some users have found that setting the autocad_original_rotation property instead of autocad_text_rotation can resolve the issue. Can you test this workaround and let me know if it resolves the issue?
