DWG to Feature Class
  • March 9, 2017
  • 79 views
I have scoured the knowledge base, YouTube etc. and I can't find an answer to my question. I have a DWG file that contains polygons and associated labels. I would like to be able to make the labels attributes of a file geodatabase feature class. From my searching I've found spatial filter but not all of the label points are located in the polygon in question. Below is one of the relevant screenshots. I only need the Dev Parcel and not the area.
Thank you.
Best answer by itay
you can use the neighbourfinder to associate the label points that are not in the polygons
itay
Forum|alt.badge.img+19
  • March 9, 2017
daveatsafe
Forum|alt.badge.img+24
  • March 9, 2017
You can also find a few more tips for associating labels with their features in this webinar:
http://www.safe.com/webinars/5-tips-for-integrating-cad-data-with-esri-arcgis/
mark2atsafe
Forum|alt.badge.img+59
Yes. Check out this exercise in the FME training course.
It grabs labels and attaches the info as an attribute onto contour features using the NeighborFinder
jneujens
  • March 13, 2017
The screenshot is missing? I am curious to see an example to give more detailed advice?
