DWG Line offset (distances from excel)
  • May 26, 2024 12:36 PM UTC
  • 0 replies
  • 84 views
stillwater
Participant
When creating offsets from a line in DWG - is it possible to use an excel table for the offset distances?
Excel table is 2 columns (“offset #” and “offset distance”) and 100+ rows (offset-1, offset-2...) containing negative and positive numbers.
I looked up offset related posts but couldn’t figure out how I could make excel work. I am using 2023.2 version and the offsetcurvegenerator has left/right inputs. Do I read the excel, then split it into positive and negative, then connect them to left / right each?
