Double value for some values convert to scientific notation using a sde reader - how can I show the actual value.
  • May 4, 2020 3:38 PM UTC
  • 158 views
The revised dataset uses a sql executor and the value is 0.00001600. The value from the sde is 1.6e-5.
When using a change detector always show as updated when the values have not actually changed. Can I fix this in the sde reader or is there a way to ensure that there is no conversion to scientific notation?
  • May 4, 2020 4:01 PM UTC
You can use a StringFormater:
You probably also want to use an AttributeRounder set to something meaningful, as comparing floats is notoriously tricky in some cases.
  • May 4, 2020 6:08 PM UTC
Worked great once I realize to add to both the origin and revised inputs. Thanks!
