Does FME Workbench write files to disk before zipping them?
  • Sep 29, 2017 2:55 AM UTC
  • 87 views
thejando
Forum|alt.badge.img+4
I am currently trying to improve the performance of a data extraction process, and I want to know if an SSD (Solid State Drive) would be beneficial for my particular workflow. The process does not get close to memory limitations, so there is no writing of temporary files (that I am aware of) to disk during the translation. The process finishes by writing a shapefile in a zip file to a local network drive. I would like to know if FME temporarily writes the shapefile to my PC harddrive before it is zipped, because if it DOES, that would suggest that an SSD would be beneficial. But if the zipping process is done entirely in memory, then I doubt an SSD would be of benefit.
Can anyone answer my question?
Best answer by danilo_fme
Hi @thejando,
I created a Workspace test to write a zip file and checked the log file about to create a temp files before create a zipfile:
Thanks,
Danilo
danilo_fme
Forum|alt.badge.img+58
  • Sep 29, 2017 5:49 AM UTC
Hi @thejando,
Thanks,
Danilo
  • Sep 29, 2017 11:29 AM UTC
If you do get an SSD disk as a non-primary disk, make sure you define the FME_TEMP environment variable and point to it.
More info here: https://knowledge.safe.com/articles/176/fme-temp-environment-variable.html
thejando
  • Oct 17, 2017 4:18 AM UTC
Hi @thejando,
Thanks,
Danilo
Thanks for your help @danilo_inovacao. I have to admit I was using an earlier version of FME (FME 2015) which logs the information in a less obvious manner. The necessary log information is still there in FME 2015, but I missed it.
thejando
Thanks for the tip @david_r
