Do you know an easy way to remove all metadata from existing pdf files?
  • Sep 15, 2021 8:43 AM UTC
  • 105 views
wicki
Forum|alt.badge.img+12
I would like to do this with the on-board resources of FME.
The PDF-Reader can read out the metadata, but can I use the PDF-Writer to overwrite it without changing the rest of the file?
An idea:
How does the FME read out the metadata? If a library such as exiftool is used for this, then this could also be done using a command line with the SystemCaller.
Forum|alt.badge.img+63
You could set up a PDF-to-PDF translation but that would literally translate all of the data (and given that PDF has some peculiarities I'm not sure how smart this is). I think an approach using a SystemCaller and an external application is indeed the way to go.
