Dividing using Expression Evaluator
  • Jul 1, 2015 11:25 AM UTC
  • 120 views
I am using ExpressionEvaluator to do a simple division: AttributeX/AttributeY.  However, I keep getting 0 as the resultant value.
When I try ExpressionEvaluator to do 5/10 it also returns 0.  But when I test 10/2 it returns 5.  Therefore I am assuming it has something to do with floats.
What should I do to get this to work?
Thanks,
fmelizard
Forum|alt.badge.img+22
  • Jul 1, 2015 11:53 AM UTC
The decimal trap no longer exists in FME 2015 so you are using an older version....see the following:https://knowledge.safe.com/communityanswers?id=906a0000000d7vTAAQ
Just add a decimal to one of the operands to resolve this, or upgrade to 2015
  • Jul 1, 2015 12:20 PM UTC
Ah ok thanks Itay, I hadn't come across this decimal trap before.
gio
Forum|alt.badge.img+15
  • Jul 3, 2015 10:53 AM UTC
it is ancient issue. It is not a trap at all. It is logic.
In older version you should always add a *1.0 to the dividor.
