Dissolver not working as expected
  • Jul 26, 2016 9:17 AM UTC
  • 159 views
I am using FME2016.1 and am trying to dissolve a series of overlapping 2D polygons.
When I run the Dissolver transformer only some of the polygons dissolve, the others disappear all together. I have a feeling the geometry of the polygons must be invalid, but when I run them through the GeometryValidator everything passes.
Any ideas?
Thanks
  • Jul 26, 2016 9:49 AM UTC
Is it because my polygons overlap and are not joined at the edges? If so, what should I do instead to get a single polygon for all polygons that intersect each other?
pratap
Forum|alt.badge.img+12
  • Jul 26, 2016 10:40 AM UTC
As far as I know, if they do not touch then it should be individual polygons as output.
could you please upload a sample of polygons which are passing and not passing to check from my end and come to conclusion
  • Jul 26, 2016 2:45 PM UTC
Actually when I ran the polygons through AreaOnAreaOverlayer first, they were dissolved correctly in most cases which I assume is because they were converted from overlapping polygons to touching polygons... But this didn't help in all cases for some reason??
jdh
Forum|alt.badge.img+41
  • Jul 26, 2016 4:45 PM UTC
Are there any warnings in the log file?
