Detecting and creating new polygons where parts of A do not overlap parts of B
  • Jun 8, 2023 2:15 PM UTC
  • 7 replies
  • 98 views
scarter
Forum|alt.badge.img+10
Hello Forum.
I have two polygon datasets (see attached image). I'd like to create a third polygon dataset showing me the sections of A that do not overlap with B. So, it would create me the polygons as highlighted in C in attached image.
I could do this via a few steps in a desktop GIS but I need to include it as part of a larger automated data flow in FME Desktop (Form).
Thanks,Swk_clip_polygons
Forum|alt.badge.img+54
  • Jun 8, 2023 2:25 PM UTC
Clip polygon A with Polygon B and keep the output from the Outside Port, followed by a deaggregator
dustin
Forum|alt.badge.img+36
  • Jun 8, 2023 2:26 PM UTC
I would use an AreaOnAreaOverlayer, generating a list on the attribute that uniquely identifies if the area is A or B (this could be the fme_basename format attribute, if they are from different datasets). Then, feed those results into a Tester or TestFilter where the condition would be _overlaps = 1, AND _list{0}.identifier = A.
scarter
  • Jun 8, 2023 2:53 PM UTC
Thanks for that, ddb. I’ve added the areaOnAreaOverlayer and a TestFilter. I’ve added the first test condition into TestFilter of @value(_overlaps_) = 1. However I cannot see a value called _list{0}. Where does that come from? Thanks, Stuart
dustin
  • Jun 8, 2023 2:59 PM UTC
You'll need to make sure you set it up in the transformer. _list is the List Name that you give it.image
scarter
  • Jun 8, 2023 3:02 PM UTC
Thanks. “You'll need to make sure you set it up in the transformer” In the Test Filter of AreaOnAreaOverlayer?
dustin
  • Jun 8, 2023 3:09 PM UTC
In the AreaOnAreaOverlayer. Although, the solution from @ebygomm​ is a really good one as well. I'm used to working with extremely dense data, and sometimes the Clipper can struggle with it. So I usually default to the AreaOnAreaOverlayer method.
scarter
  • Jun 8, 2023 3:13 PM UTC
Thanks.
