DEM Raster Feature class to JPEG
  • Apr 25, 2024 4:58 PM UTC
  • 150 views
coreyross
Good morning,
I am reading a DEM stored as a raster feature class in a gdb, clipping to an AOI and then writing to JPEG to be used in road design software.
I can read and clip properly but having trouble writing to JPEG. I have gathered I need to set up bands differently but I have tried the rasterbandinterpretationcoercer and rasterbandadder and rasterinterpretationcoecer in various configurations/settings and can’t seem to get it to write a JPEG. Usual error is about the number or type of bands depending on how I set the coercers etc.
DEM raster feature information
Any suggestions would be welcome.
Thank you so much,
Corey
debbiatsafe
Forum|alt.badge.img+24
Hello @coreyross
The second band in your raster is odd. Band 0 with the actual DEM values is real32 while band 1 is an alpha8 band with nodata as 255.
If band 1 doesn’t contain valid data, you can try separating the two bands with a RasterBandSeparator, select band 0, then use a RasterInterpretationCoercer to coerce band 0 to Gray8 (or another JPEG supported band interpretation) before the JPEG writer.
coreyross
  • May 1, 2024 1:07 AM UTC
Thanks for this help. This has got the JPEG writing and that’s a huge help. I did a quick test and I am not sure the elevation values are being written but I need to do a bit more digging.
Edit: It just occurred to me it might not be possible to store elevation information in a jpg of this type. I need to check with the end user how they are using this raster in their process. It may only be a visual aid.
Thanks again,
Corey
Hello @coreyross
