Define Categories based on values
katt
Forum|alt.badge.img+12
Hello, I have a table with 3 records per house. The table includes hundreds of houses. I want to create a new attribute called Type. There are two types only : A and B.
For Type A: two values of attribute a1 per house equal the value of attribute a2 of another record of the same house.
For Type B: two values of attribute a2 per house equal the value of attribute a1 of another record of the same house.
How can I automatically assign the type to each record of any given house? Thx.
crutledge
Forum|alt.badge.img+30
  • April 17, 2025
Hi ​@katt
Could you count the number of times a record occurs per house in a1 and a2 then if a1_count = 2 then Type A and if a2_count = 2 then Type B?
geomancer
Forum|alt.badge.img+47
  • April 17, 2025
You give a nice example, because just counting the number of times a record occurs per house in a1 and a2 does not work. House x has 2 occurences of 12 in a1, and 2 occurences of 10 in a2. But the value 10 is not present in a1.
Calculate the Histogram in a StatisticsCalculator, then determine the Type. See the attached example (FME 2024.1).
  • April 17, 2025
Count the number of features having the same value in a1 and a2 for each House, then determine Type of House according to the criteria:
If count of a1 = 2 AND count of a2 = 1 Then A
Else if count of a1 = 1 AND count of a2 = 2 Then B
See also the attached workspace example.
