Decimal equivalant to INT
  • December 20, 2013
  • 6 replies
  • 121 views
within a workbench I need to split a decimal value into its whole and decimal elements using the arithmetic editor,
Extracting the whole number is easy using INT(value), however is there a formula available which will complete the same procedure with eh decimal?
I have used a workaround in the form of (value)-INT(value) which works fine, but I am interested to know if there is an out of the box formula which will do this?
Regards,
Rob
Forum|alt.badge.img+53
  • December 20, 2013
You can use fmod to get the decimal part
In an expression evaluator
@fmod(@Value(attribute), 1.)
will give you the decimal elements
  • December 20, 2013
Many thanks, that worked a treat.
Best wishes,
Rob
  • December 21, 2013
Hi Rob,
Just be aware the expression returns a negative value if the original value is negative. @fmod(-1.234,1)  -->  -0.234   and also, it could bring a slight computational error in certain conditions. @fmod(1.001, 1) --> 0.00099999999999989   Alternatively, the StringSearcher could be used to split a numeric representation into integer part and decimal part at once.
  Takashi
  • December 24, 2013
If you have the INT() function to get the integer part, why not subtract the integer part from the original to get the decimal? So: dec(x) = x - int(x).
  • December 24, 2013
Woops, only just noticed you have my answer in your question. I don't think there is an out of the box formula, especially with only a small custom formula required.
  • January 8, 2014
Many thanks to everyone for the answers and suggestions, plus the overview of the potential calc issue of using fmod.
Regards,
Robb
