dbms error ora-12899
  • May 8, 2014 1:00 PM UTC
  • 10 replies
  • 81 views
francis_m
Forum|alt.badge.img+9
Hi FME users!
I have a workbench that read Mapinfo tab file and write it to a GEODATABASE_SDE into Oracle.
The error is very weird.  Some record pass but there is a fail on some others.
The errors is :
ERROR |An error occurred while attempting to insert a row into the table 'VLORA1A.ENVIRONNEMENT' using a cursor. The error number from ArcObjects is: '-2147216072'. The error message from ArcObjects is: {Underlying DBMS error [ORA-12899: valeur trop grande pour la colonne "VLORA1A"."ENVIRONNEMENT"."REMARQUE_ELEM" (réelle : 266, maximum : 254)
but the value REMARQUE_ELEM is empty in my data :
2014-05-08 08:40:04| 330.5|  0.0|ERROR |Attribute(string)        : `PORTEE_A' has value `1001'
2014-05-08 08:40:04| 330.5|  0.0|ERROR |Attribute(string)        : `PORTEE_DE' has value `1001'
2014-05-08 08:40:04| 330.5|  0.0|ERROR |Attribute(string)        : `REMARQUE_ELEM' has value `'
2014-05-08 08:40:04| 330.5|  0.0|ERROR |Attribute(string)        : `RESPONSA' has value `St-Hubert'
2014-05-08 08:40:04| 330.5|  0.0|ERROR |Attribute(encoded: utf-8): `SUFCIREF' has value `'
You can see that the value REMAQUE_ELEM is empty.
Even if I try with a value like "PONCEAU" it fail.
But Other records with value like "Cabane à sucre, montée Lapointe" pass perfectly
The column in Oracle is formated like this :
REMARQUE_ELEM : VARCHAR2(254 BYTE)
Do I have to reset the Oracle Table, is it the registry SDE ?
It looks like the registry of SDE is synchro with the Oracle table.
any help would be appreciated!
thanks!
  • May 8, 2014 1:34 PM UTC
first of all, you could try using an AttributeTrimmer on REMARQUE_ELEM to see if that helps.
If not, make sure that REMARQUE_ELEM is defined with a max length of 254 characters in the FME output feature type.
David
francis_m
  • May 8, 2014 1:42 PM UTC
Hi David,
I already have an attribute trimmer down to 253.
I also clean the attribute of all blank space that are unnecessary.
And my FME output feature type is a char 254.  Seems all clean.
I suspect more the mapinfo.  If i run the workbench with a max feature read, it goes well and no fail.  But if I read the whole thing (more than 7000 objects) it fail...
GRRRRR
  • May 8, 2014 2:42 PM UTC
how about inserting a SubstringExtractor just before the output feature type? Send End Index to 253.
David
francis_m
  • May 8, 2014 2:54 PM UTC
What I actually do on the painfull ATTRIBUTE :
1 - clean the blank space with AttributeTrimmer
2 - Calculate the string lenght
3 - if the string lenght is longer than 253 I do a SubstringExtractor (0-252)
I'm now trying with encoding and decoding just before writing into gdb_sde but still fail
francis_m
  • May 8, 2014 3:03 PM UTC
I can push value like "3023, CH. DE LA BUTTE-AUX-RENARDS, VARENNES, COORDONNÉES APPROXIMATIVES" but "PONCEAU" won't pass...
  • May 8, 2014 3:12 PM UTC
And if you look at the field definition of REMARQUE_ELEM in ArcCatalog, which length is given there?
David
francis_m
  • May 8, 2014 3:25 PM UTC
The GDB say : Text 254...
If I change the value in the MapInfo file it pass.
If I wrote back the same value (not copy paste) it pass too...
It's the mapinfo I think.  But how can I manage this into a workbench...
francis_m
  • May 8, 2014 6:18 PM UTC
Well, after many test, the mapinfo is OK, the workbench seems perfect.
it looks like a db problem.  but the dba is off for the week.  not good.
Any idea welcome!
francis_m
  • May 8, 2014 6:19 PM UTC
If I read just a few records (including the one that make fme fail earlier) : full success.
If I read many records (including the one that make fme fail earlier : FAIL
francis_m
  • May 14, 2014 4:24 PM UTC
Hi David,
We finally resolve this :
My attribut is 254 char (varchar2 in oracle).
But Oracle record the data in HEX encoding and my limit is 508 bytes (2x254 = 508 bytes).
So I have to test the lenght of the value to be lower than 254 and the lenght of the value in hexadecimal have to be lower than 508.  If not (in a loop) I test those lenght until I reach the maximum permitted.
Thank you for your help.
The problem I don't like is that FME was logging me the wrong entity when the fails occured.
The entity after was the problem... I think you should check this.
It's the first time it happens to me.
