DateTimeParse - why does this not work?
tim_wood
Forum|alt.badge.img+8
The DateTimeParse function is driving me mad (in FME 2018.1)!
What is the problem with this...?
Failed to evaluate expression '@DateTimeParse(3-Jun-2020,%Y%m%d,repair)'. Result is set to null
I have also tried @DateTimeFormat and @DateTimeCast and things like putting quotes around the input etc. Nothing works.
I want to use the function because I want to convert a value of "3 June 2020" to 2020-06-03 to write into a date field in SQL Server. I have already use the string functions to extract the substrings for day (3), 3 character month (Jun) and year (2020). I could go the long winded way and write these to separate attributes then use the DateTimeConverter transformer, but why should I?
Best answer by david_r
The specified format does not correspond to the input format. Try:
@DateTimeParse(3-Jun-2020,%d-%b-%Y,repair)
Result: 20200603
If you need a specific output format, you need to chain it with the DateTimeFormat:
@DateTimeFormat(@DateTimeParse(3-Jun-2020,%d-%b-%Y,repair),%Y-%m-%d)
Result: 2020-06-03
Also look at the documentation:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/!Transformer_Parameters/Date-Time-Functions.htm
  • January 17, 2020
Result: 20200603
Result: 2020-06-03
tim_wood
  • January 17, 2020
For info, DateTimeConverter works (see below). So how do I do this using function(s) in the Text Editor?
  • January 17, 2020
This is because the DateTimeConverter does two things: first a @DateTimeParse (input format), then a @DateTimeFormat (output format).
tim_wood
  • January 17, 2020
Result: 20200603
Result: 2020-06-03
Hi @david_r I have been looking at the documentation. The examples are pretty basic and I couldn't see anything that tells you how to parse/format AND convert to a different date format. But I tried your suggestion in the comment above and that works, so thank you :-)
Here's the whole thing for anyone that's interested:
@DateTimeFormat(@DateTimeParse(@Substring(@Value(Col2),0,@FindString(@Value(Col2)," "))-@Substring(@Value(Col2),@FindString(@Value(Col2)," ")+1,3)-@Right(@Value(Col2),4),%d-%b-%Y,repair),%Y%m%d)
  • January 18, 2020
If you intend to convert "3 Jun 2020" to "20200603" for example, the expression you quoted is a bit redundant, this expression should work as well.
@DateTimeFormat(@DateTimeParse(@Value(Col2),%d %b %Y,repair),%Y%m%d)
tim_wood
  • January 20, 2020
Will that work on full month names? Maybe the "3 JunE 2020" example wasn't the best one. My source date values are like this:
4 January 2020
15 February 2020
I have assumed that I need to trim the month text down to 3 characters before doing anything else.
  • January 20, 2020
4 January 2020
15 February 2020
As per the documentation, %b corresponds to the abbreviated, 3-letter English month name.
For the full (not abbreviated) English month name, use %B in stead (upper case).
tim_wood
  • January 20, 2020
Ah!  I was looking for that in the documentation but obviously missed it.  So I should be able to simplify my code to what Takashi suggests with that amendment...
@DateTimeFormat(@DateTimeParse(@Value(Col2),%d %B %Y,repair),%Y%m%d)
  • January 20, 2020
Or even shorter, based on my first reply:
DateTimeParse will return the FME datetime format, meaning that you don't have to specifically format it as such.
tim_wood
  • January 20, 2020
Works a treat!  You guys are the best :-)
