DateTimeCalculator handling of minus numbers
  • Mar 12, 2020 4:07 PM UTC
  • 71 views
kevinfrench
Participant
I am trying to use the DateTimeCalculator on the calculate interval between two datetimes. The results I will get will be negative number as the date will be before the start date.
I am getting all the results rejected. Can the DateTimeCalculator output positive and negative numbers in the results?
Looking to use this for stats between two dates and if under and over the target date.
Thanks
Kevin
Forum|alt.badge.img+54
  • Mar 12, 2020 4:10 PM UTC
Yes, it will output negative numbers if you ask it to calculate the difference between two dates where the end date is earlier than the start date.
Are you sure you have the dates correctly formatted?
kevinfrench
Participant
  • Participant
  • Mar 13, 2020 9:34 AM UTC
Thanks for the reply.
I will look at my data as there must be an issue with this then.
Thanks
Kevin
