Creating individual polygons
  • Mar 12, 2020 8:22 PM UTC
  • 95 views
dszarka
I have two MicroStation Files, one is a parcel map with parcel numbers inside each parcel polygon. The second file is a right of way polygon that intersect the parcels. How do I create individual parcel polygons of just the right of way intersections and attribute each polygon with the parcel number?
Best answer by daveatsafe
Hi @dszarka,
You can attribute the parcel polygons with the parcel number using PointOnAreaOverlayer transformer, with Attribute Accumulation set to Merge Attributes. After this, you can use a Clipper transformer to clip the attributed parcels by the right of way polygon.
daveatsafe
Forum|alt.badge.img+24
  • Mar 12, 2020 9:13 PM UTC
Hi @dszarka,
dszarka
  • Mar 13, 2020 4:13 PM UTC
Hi @dszarka,
Thank you for your suggestions. I was able to almost accomplish what I wanted to do. The thing that I'm still struggling with is how to write out only the polygons and parcel numbers that have an overlap of 2.
daveatsafe
  • Mar 13, 2020 6:35 PM UTC
Hi @dszarka,
You can test the value of the _overlaps attribute in a Tester transformer.
