Creating a point featureclass
  • Mar 19, 2018 7:06 PM UTC
  • 115 views
I have 5 polygon featureclass and 1 point featureclass. I would like to create a point featureclass that contains certain attributes from each of the polygon featureclass. How would I go about doing this.
Thank you in advance.
erik_jan
Forum|alt.badge.img+26
  • Mar 19, 2018 7:18 PM UTC
Can you use the Center point of the polygons?
The CenterPointReplacer transformer replaces the polygon by a center point and then you can write those points to the point feature class.
jdh
Forum|alt.badge.img+41
  • Mar 19, 2018 8:06 PM UTC
I would use a PointOnAreaOverlayer to get the attributes from the various polygon featureclasses.
erik_jan
  • Mar 19, 2018 8:46 PM UTC
Could you clarify the issue:
Do you want points representing the polygons or do you want attributes from the polygons copied on the existing points?
Solutions for both options are already listed below.
