Create Single Lines From Points
  • September 17, 2021
  • 745 views
Hello everyone!
My problem:
I have a list of points, each point (of course) has coordinates and a timestamp. I would now like to create individual lines from the points and each line should store the two timestamps of the two points it was created from.
I've already tried the LineBuilder, but there I get a polyline.
Source:
Point a, b, c, d
Result LineBuilder:
Line 1: from a to b to c to d
Result I want:
Line 1: from a to b, Attributes: Timestamp_A, Timestamp_B
Line 2: from b to c, Attributes: Timestamp_B, Timestamp_C
Line 3: from c to d, Attributes: Timestamp_C, Timestamp_D
Any ideas?
Best answer by chrisatsafe
Hi @ferorelatum​ ,
How about something like this:
2021-09-17_9-16-09
Use the LineBuilder as you normally would, then use the Chopper to split the line based on 2 vertices. Next, using a SpatialFilter, you can generate a list from points that touch each line and create the tiemstamp 1 and 2 attributes and set the value from the list.
There are likely other ways to accomplish this as well but I've attached a sample workspace in case that helps.
chrisatsafe
Hi @ferorelatum​ ,
2021-09-17_9-16-09
chrisatsafe wrote:
Hi @ferorelatum​ ,
2021-09-17_9-16-09
@chrisatsafe​ , works fine. Thanks!
