Create same geometry with different attributes
  • Nov 21, 2021 2:00 AM UTC
  • 60 views
Hi, I have a polygon layer that represents the building footprint (attribute: building id). In .csv I have a list of apartments (attributes: building id, Apartman id). One building consists of x apartments. So, I need to x duplicates of the building footprint and each clone needs to have a different apartment id. I used the FeatureMerger to join shp and csv and clon to create duplicates of geometry but all duplicates have the same apartment id.
connecter
Forum|alt.badge.img+10
  • Nov 21, 2021 11:15 AM UTC
Hi @moset221​
here is a small workflow with hopefully similar to your data:
imageMy results:
imageWhen you have further trouble, can you please share some screenshots or data?
@moset221​ or try FeatureJoiner with the Left as your buildings and the Right as the CSV input.
