Create polygon from single point
ingalla
Forum|alt.badge.img+10
Hi
I am sure that I have seen this before but how can I create a polygon from a single point. I only want to make the polygon 3m in diameter. I thought that there was a transformer but I can not find anything now....
Any suggestions welcome.
Best answer by takashi
Hi @ingalla, if you need a circular-shape polygon, the Bufferer might help you.
  • May 20, 2016
  • May 20, 2016
And to add to that you could also add a BoundingBoxReplacer after the Bufferer to create a nice square.
ingalla
  • May 20, 2016
That's great, thanks for your help, all works well....
erik_jan
Forum|alt.badge.img+20
  • May 20, 2016
Even a rectangle can be made directly from the Bufferer if you set the end type to square.
