create custom text file
  • Jun 11, 2018 4:57 PM UTC
  • 224 views
I need to output an SQL script created with SQL Creator in a custom text file. The file is essentially a csv file but with '|' as the seperator, the header row prefixed with a 'H|' the rows of data prefixed with 'B|' and a footer containing F|<file_id>|<datetime_stamp>|<number_of_rows>
creating a csv file using '|' is easy enough but I haven't found a way to do the prefixes or footer. I was looking at using XML Templater but not sure if I'm barking up the wrong tree.
Any guidance would be greatly appreciated.
Best answer by takashi
Another thought. Create a CSV file without footer line using the FeatureWrite (Format: CSV), then create and append footer line to the file aftterward.
jdh
Forum|alt.badge.img+41
  • Jun 11, 2018 8:55 PM UTC
I would be tempted to use a Creator and AttributeCreators, along with a StatisticsCalculator or Aggregator to get the Feature count and send them all to a text writer.
  • Jun 11, 2018 11:09 PM UTC
