Create column from row values and transpose Attribute values
iveline
I need help
I have this table
ID Année Logements
20 2024 120
20 2025 210
20 2026 340
I would like to obtain this :
ID Année_2024 Année_2025 Année_2026
20 120 210 340
Thank you so much for your help!
Best answer by hvukasinovic
You could achieve this using lists. Here is an example how it can be done, assuming that you don’t have large number of years to cover.
(Apart from ID=20, I added another feature with ID=21 that is missing record for 2026)
hvukasinovic
Forum|alt.badge.img+13
  • July 24, 2024
hvukasinovic
This approach might be even better as you don’t have to list all key/value pairs.
(workspace with both options is attached)
iveline
  • July 25, 2024
Thank you so much hvukasinovic, it works perfectly.🙏🏾
