Create a zip from line and polygone shapefile
  • Jun 14, 2024 2:26 PM UTC
  • 120 views
hugues
Hi.  I’ve a FGDB how contains polygone and line feature,.
I need to create a separate shapefile for all feature of the FGDB.
After that, I’ve to create a zip with all the shapefile.
Can i do that with FME ?
Thank for help
danilo_fme
Forum|alt.badge.img+58
  • Jun 14, 2024 2:33 PM UTC
Hi @hugues
You can use the Generate Workspace and the fanout option.
Thanks in Advance,
Danilo
thomasmarti
Forum|alt.badge.img+9
  • Jun 17, 2024 11:10 AM UTC
if you want to automate the zip-process, you can use it in combination with the WorkSpaceRunner transformer.
  1. First workspace does all the work and export the fgdb
  2. the second workspace initialise the WSR-transformer with the first workspace and zips afterwards the files with the ZipArchiver (FME HUB transformer)
geomancer
Forum|alt.badge.img+71
  • Jun 17, 2024 1:53 PM UTC
You can also export the FGBD to temporary shapefiles using the TempPathnameCreator transformer, and add all data to a single shapefile (or several shapefiles) in the same workspace.
