Create 3D mesh DTM from rasters,Create a 3D DTM from photo raster and elevation raster
  • August 27, 2018
  • 252 views
Hye,
I'm trying to create a 3D terrain model (export format : .obj/.fbx/.3ds or any other textured mesh format) from imagery raster (France, IGN) and elevation raster (France, IGN).
Inputs formats are :
1. For imagery
Multiple *.jp2 files with *.tab files associated (same file name)
A sample of .tab file :
!table
!version 300
!charset WindowsLatin1
Definition Table
File "01-2015-0830-6540-LA93-5M00-E100.jp2"
Type "RASTER"
(830000.00,6540000.00) (0,0) Label "Pt 1",
(840000.00,6540000.00) (2000,0) Label "Pt 2",
(840000.00,6530000.00) (2000,2000) Label "Pt 3",
(830000.00,6530000.00) (0,2000) Label "Pt 4"
CoordSys Earth Projection 2003337346.54449.000000000017000006600000, -792421527823135207789741029
Units "m"
2. For elevation
Multiple *.asc files with *.asc.aux.xml files associated (same file name)
An extract of *.asc file :
ncols        1000
nrows        1000
xllcorner    74962.500000000000
yllcorner    6750037.500000000000
cellsize     75.000000000000
NODATA_value  -99999.00
 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -99999.00 -9999[...]
An extract of *.asc.aux.xml file :
<PAMDataset>
  <SRS>COMPD_CS["RGF93 / Lambert-93 + NGF-IGN69 height",PROJCS["RGF93 / Lambert-93",GEOGCS["RGF93",DATUM["Reseau_Geodesique_Francais_1993",SPHEROID["GRS 1980",6378137,298.257222101,AUTHORITY["EPSG","7019"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6171"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4171"]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["standard_parallel_1",49],PARAMETER["standard_parallel_2",44],PARAMETER["latitude_of_origin",46.5],PARAMETER["central_meridian",3],PARAMETER["false_easting",700000],PARAMETER["false_northing",6600000],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["X",EAST],AXIS["Y",NORTH],AUTHORITY["EPSG","2154"]],VERT_CS["NGF-IGN69 height",VERT_DATUM["Nivellement General de la France - IGN69",2005,AUTHORITY["EPSG","5119"]],UNIT["metre",1,AUTHORITY["EPSG","9001"]],AXIS["Up",UP],AUTHORITY["EPSG","5720"]],AUTHORITY["EPSG","5698"]]</SRS>
  <PAMRasterBand band="1">
    <Metadata>
      <MDI key="STATISTICS_MAXIMUM">102.4</MDI>
      <MDI key="STATISTICS_MEAN">43.77518150174</MDI>
      <MDI key="STATISTICS_MINIMUM">-2.79</MDI>
      <MDI key="STATISTICS_STDDEV">26.137841691288</MDI>
    </Metadata>
  </PAMRasterBand>
</PAMDataset>
I'm discovering FME and I'm working with a demo licence, so I need a complete explaination of the workflow please...
And... I'm French, so... my english is very bad :/ Sorry !
Hye,
1. For imagery
!table
!version 300
Definition Table
Type "RASTER"
Units "m"
2. For elevation
ncols        1000
nrows        1000
<PAMDataset>
    <Metadata>
    </Metadata>
  </PAMRasterBand>
</PAMDataset>
daveatsafe
Forum|alt.badge.img+19
  • August 27, 2018
Hi @loicroybonjob,
The basic process would be to use CsmapReprojectors to reproject the data into a common coordinate system (if they are not already in one), then use a TINGenerator to convert the elevation raster to a surface. Next, use an AppearanceSetter to texture the surface, with Texture Coordinate Generation Parameters -> Texture Mapping Type set to Top Down Georeferenced.
The resulting textured surface can then be written to your desired 3d output format.
texturedem.fmw
