Count number Points in a Polygon
  • September 28, 2017
  • 5 replies
  • 479 views
anthrax_79
Forum|alt.badge.img+4
Hi, I am still new in FME. and I want to count the number of points in a polygon and results should show number of points via the polygon ID
my database are all in shapefiles and have same coordinate systemPolygonNumber of points insideRegion 125Region 265
if someone can please post a step by step that would be highly appreciated.
thanks
Lex
Best answer by danilo_fme
Hi @lexadove731,
I believe the transformer PointOnAreaOverlayer is good for you.
This transformer has two Input ports ( Points and Area ).
A new attribute is created by this transformer : _overlaps ( with number of points inside ).
Results:
Thanks,
Danilo
ciarab
Forum|alt.badge.img+9
@lexadove731
you should be able to achieve this easily by adding your points and you polygons and the using the pointonareaoverlayer transformer
Using the output port there should be an attribute on the polygons called _overlaps this will give a count of the number of points inside
https://docs.safe.com/fme/2017.1/html/FME_Desktop_Documentation/FME_Transformers/Transformers/pointonareaoverlayer.htm
danilo_fme
Forum|alt.badge.img+45
Hi @lexadove731,
Results:
Thanks,
Danilo
danilo_fme
  • September 30, 2017
ciarab wrote:
@lexadove731
Good Job @ciarab
anthrax_79
  • October 5, 2017
danilo_fme wrote:
Hi @lexadove731,
Results:
Thanks,
Danilo
thanks for your reply. sorry i was in holiday. I tried that before asking here but I couldn't figure it out. it was not giving any results. I can see the_overlaps but however the output is still empty. sad to say but i have used a different ways to get what i want.
would be good to further improve my skills in FME as i think it is very usefull and diverse.
anthrax_79
  • October 5, 2017
ciarab wrote:
@lexadove731
thanks mate. i will check out the link and do more study and training.
cheers
