count number of points in a solid
  • Nov 29, 2018 2:23 PM UTC
  • 172 views
Hi FME community
I try to count the number of points (from *.las point cloud) in a solid. The solid comes from an extruded polygon.
The goal of it is to figure out if the point cloud matches an existing 2D CAD Plan. To do this I take the polyline of the walls and extrude them. Afterwards I would like to count the number of point inside the extruded solid (wall). If this results in many points I can assume that the wall is correct - if not the wall must be incorrect.
It would be great if someone has any idea and can help me. I only struggle with the count of the points in the solid.
Thanks in advance and kind regards form Switzerland
Dominik
Best answer by dominik
Hi takashi
Thanks for your effort and answer. In the meantime I figure out a similar way:
1. I use the 2DForcer for the point cloud (so every point is on z=0)
2. I use an PointOnAreaOverlayer to count the number of points inside the wall
This works perfect for me!
Thanks anyway!
Dominik
  • Nov 29, 2018 3:01 PM UTC
Hi, if the solid is a simple one which is created by extruding a flat polygon towards z-axis direction, a possible way is:
  1. BoundsExtractor: Extarct zmin and zmax of the extrusion solid.
  2. SurfaceFootprintReplacer: Replace the solid with a 2D polygon.
  3. Clipper (Check the Merge Attributes option): Clip the point cloud by the polygon.
  4. PointCloudFilter: Create a point cloud consisting of points whose z-coordinate are within the zmin and zmax.
  5. PointCloudPropertyExtractor: Count the number of the resulting point cloud.
gio
Forum|alt.badge.img+15
  • Nov 29, 2018 3:05 PM UTC
@dominik
You can use a clipper for that
Use your solid as clipper.
  • Nov 29, 2018 3:07 PM UTC
Hi takashi
Thanks anyway!
Dominik
  • Nov 29, 2018 3:08 PM UTC
@dominik
I didn't know the Clipper supports 3D clipping on point cloud. Good to hear :-) Thanks.
