Converting UTC datetime to CET/CEST
fgiron
Forum|alt.badge.img+21
I'm trying to convert UTC datetimes to CET/CEST but can't find the way of getting a datetime that takes into account the Daylight Saving Time differences. The local settings of the DateTimeStamper or @TimeZoneSet function are of no use because the workspace is run in an FME Server where the local time is UTC.
Thanks a lot in advance!
Francisco
  • April 25, 2020
Hi @fgiron, according to the definition of CET/CEST, timezone +02:00 is applied in 210 days between 01:00 UTC on the last Sunday of March and 01:00 UTC on the last Sunday of October, otherwise timezone +01:00 is applied. Therefore, if you get start and end dates of the CEST duration in the year, you can determine the correct timezone for a specific datetime by testing the datetime is within the duration.
This screenshot illustrates a possible way.
Alternatively, a PythonCaller with this script works as well.
from datetime import datetime, timedelta
class CESTStartEndDatetimeCalculator(object):
    def __init__(self):
        self.cestStartEnd = {}
    def input(self, feature):
        def getCestStartEnd(year):
            s = datetime(int(year), 3251)
            while s.strftime('%w') != '0':
                s = s + timedelta(days=1)
            e = s + timedelta(days=210)
            return (
                s.strftime('%Y%m%d%H%M%S') + '+00:00',
                e.strftime('%Y%m%d%H%M%S') + '+00:00'
        year = str(feature.getAttribute('_timestamp_utc'))[:4]
        s, e = self.cestStartEnd.setdefault(year, getCestStartEnd(year))
        feature.setAttribute('_cest_start_datetime', s) # 01:00 UTC, the last Sunday of March
        feature.setAttribute('_cest_end_datetime', e) # 01:00 UTC, the last Sunday of October
        self.pyoutput(feature)
    def close(self):
        pass
Forum|alt.badge.img+40
  • April 27, 2020
Dateutil has a timezone module so another python solution
import fme
import fmeobjects
from dateutil import tz
def convertUTC(feature):
    from_zone = tz.gettz('UTC')
    to_zone = tz.gettz('Europe/Paris')
    utc = datetime.strptime(str(feature.getAttribute('date')), '%Y%m%d%H%M%S')
    # set date to UTC
    utc = utc.replace(tzinfo=from_zone)
    # Convert time zone
    central = utc.astimezone(to_zone)
    feature.setAttribute("converted_date", central.strftime('%Y%m%d%H%M%S%z'))
fgiron
  • April 27, 2020
    def __init__(self):
            return (
    def close(self):
        pass
Hi @takashi, thanks a lot for your answer!
It hadn't occurred to me that summer time always lasts the same. Nor had I thought about replicating the algorithm (last Sunday of March/October) in FME. I love it!!
fgiron
  • April 27, 2020
import fme
import fmeobjects
    # set date to UTC
    # Convert time zone
Hi @ebygomm, very nice and simple python script. It looks like a very simple possible addition to the DateTimeCalculator. Thank you!!
