Converting Lines\\Arcs of AutoCAD to Areas (polygons),
jamal
Forum|alt.badge.img+5
Converting lines\\Arcs of AutoCAD to Areas (polygons),
I couldn’t figure out which transformers can convert the lines\\Arcs of AutoCAD format to Areas (polygons)
The workbench below fails to do so
The dwg is stored in the link below
http://www.mediafire.com/download/kjl41kwkol0nboy/T24.dwg
Thank you
Best
Jamal
Best answer by takashi
Hi Jamal,
Maybe need some trial and error. For example, two AreaBuilders with different snapping tolerance might be effective in this case.
Takashi
  • April 5, 2015
Hi Jamal,
Takashi
jamal
  • April 6, 2015
Thank you very much Takashi for the help. It works like a charm after playing a bit with the tolerance.
