Convert SHP to GDB and use certain folder names as the feature class names in which SHPs will be converted into.
  • Jun 7, 2022 5:08 PM UTC
  • 106 views
I have numerous shapefiles in numerous folders. While I can parse through all of these and convert directly into a GDB I will have 203 separate classes. I would like to use the parent folder name as my feature class name. Each folder has a varying number of SHPs in it but they all belong to their parent folder. Inside the parent folders, SHPs Parent folders each containing numerous SHPs
chrisatsafe
Hi @sjolster31​ ,
You should be able to get this done by exposing the fme_dataset format attribute and passing that into the FilenamePartExtractor. This will create a new attribute (_dirname) which you can then use to Fanout to create feature classes.
  • Jun 7, 2022 5:45 PM UTC
Thank you, I shall give this a go!
