Convert json-file to ESRI line feature class
ireen
Forum|alt.badge.img+5
I have a json-file (see attachment) that contains the coördinates of a circular route. It looks like this:
 "segments": [{
  "geometry": {
   "type": "LineString",
   "coordinates": [
    [50.814103, 4.521174],
    [50.81309, 4.521811],
    [50.80626, 4.536902],
    [50.80482, 4.538866],
    [50.80573, 4.541452],
    [50.80621, 4.543173],
    [50.80705, 4.545501],
    [50.80755, 4.546541],
    [50.80777, 4.546841],
    [50.80919, 4.547739],
    [50.8096, 4.548199],
    [50.81052, 4.550243],
    [50.810663, 4.551096]
  "geometry": {
   "coordinates": [
    [50.810663, 4.551096],
    [50.81065, 4.555264],
    [50.81071, 4.555622]
I want to convert it to an ESRI line feature class, but I'm stuck. The geojsonreader gives no error, but also no result as reader.
Json-fragmenter gives me the list of vertices in an attribute, but I can't fix it to convert these points to vertices/line.
imageSomeone who can help me out?
Best answer by nielsgerrits
ireen wrote:
This is what I was looking for. Thanks a lot!!
As always the are different approaches to solve these things. I attached a workspace which solves the segments in a more elegant way. The geometry in the nodes and unpaved segments is not in a default format, so this still need to be done manually.
2023-03-28_10h17_24
nielsgerrits
Forum|alt.badge.img+54
Use a JSONFragmenter with the query
json["segments"][*]["geometry"]
to get the individual geometry per segment, then use a GeometryReplacer set to GeoJSON to get the geometry from it.
2023-03-27_13h33_12
ireen
  • March 27, 2023
2023-03-27_13h33_12
nielsgerrits
cheers:)
ireen
  • March 28, 2023
Niels,
To extract the nodes from the json-file, I did the following:
imageThis works fine, but I assume there is an easier way to get the points (including their attributes)?
ireen
  • March 28, 2023
2023-03-27_13h33_12
Looking at the result, I see that the spatial location is not correct. The GeometryReplacer translates the [Lat,Long] to [X,Y] instead of [Y,X]. The GeoJSON Geometry encoding has no possibility to change the axis order. Anybody an idea to solve this?
nielsgerrits
Yes I just found the same :) The CoordinateSwapper can fix this.
nielsgerrits
  • March 28, 2023
2023-03-28_10h17_24
ireen
  • March 28, 2023
Where exactly in the FeatureReader do you define the queries for the output ports?
imageI did this, but no succes:
nielsgerrits
This is correct, then under Parameters set Geometry Format to GeoJSON and set Geometry Key Name = "geometry".
2023-03-28_11h05_26
ireen
  • March 28, 2023
Thank s a lot, Niels. Works fine.
