Configure 32 bit and 64 bit engine in same fme server
  • Feb 12, 2020 3:30 PM UTC
  • 56 views
How to configure 2 engines one is with 32 bit and another with 64 bit in same fme server
stalknecht
Forum|alt.badge.img+22
  • Feb 12, 2020 3:48 PM UTC
  • Feb 12, 2020 3:57 PM UTC
Thanks for the reply, Followed the same configuration steps, but no luck engine2 was hidden after this configuration steps
stalknecht
  • Feb 12, 2020 4:21 PM UTC
So you've followed:
https://docs.safe.com/fme/html/FME_Server_Documentation/AdminGuide/Install_32_and_64_Bit_Engines_On_Same_Machine.htm
Can you share the processMonitorConfigEngines file?
