Concatenating fields - cross tabulation
  • February 17, 2015
  • 7 replies
  • 84 views
Hi all,
I have a table in Excel that looks like (I have added he Case rows to make it clearer):
I have been asked to concatenate fields when for the same site there are two different countries or two different regions or both, as follows:
Does anyone have an idea of how I could achieve that in FME so that I can get the concatenation done for the three cases?
Best answer by takashi
Hi Darius,
Assuming that the concatenation should be performed for each Site group (1A, 2Z, and 3W in the example), I would use two Aggregators in a series.
1st Aggregator
Group By: SiteCode, County
Mode: Attributes Only
Keep Input Attributes: Yes
Attributes to Concatenate: Region
Separatoe Character: & (surround by whitespaces)
2nd Aggregator
Group By: SiteCode, Region
Attributes to Concatenate: County
Separator Character: & (surround by whitespaces)
If you will respect the order of input features, expose "xlsx_row_id" in the Excel reader feature type, and insert the Sorter between the two Aggregators to sort by "xlsx_row_id".
Takashi
  • February 17, 2015
Hi Darius,
1st Aggregator
2nd Aggregator
Takashi
  • February 17, 2015
Takashi, your approach worked nicely and efficiently. I didn't think the solution was so straightforward.
Thanks for your priceless help!
Darius
  • February 18, 2015
Good to hear that you accomplished the purpose.
In addition, try setting "Yes" to "Input is Ordered by Group" parameter of the Aggregators, if rows which contain attributes that should be concatenated are always consecutive. In this case, the Sorter would not be essential to keep the input order.
majdoleen
  • June 28, 2015
Hi All,
Thank you I found this very useful, I have started the workbench as seen in the attached, and it is working fine, but the problem that I got simillar value in the row (attached), any Idea how to remove the identical value in the row,
which tool is missing here?
Best,
Majdoleen
  • June 28, 2015
Hi Majdoleen,
How about using the DuplicateRemover?
Takashi
majdoleen
  • June 28, 2015
Thank you Takashi, but please could you explain more in details where I have to use it and what it must contains? I am new in FME.
Best,
Majdoleen
majdoleen
  • June 28, 2015
yes it is working perfect.
Thank you Takashi, really appreciate.
Best,
Majdoleen
