Parcels are created, removed or changed in GIS, but we also have a CAD Map3d basemap that we also maintain. One of these basemaps contains a text layer that has the address number for each parcel, what I am trying to do is compare the parcel address number from the GIS against the cad basemap find out which ones have changed, removed or inserted then make the changes to the cad file.
I have already setup readers for the GIS and CAD parcel polygons and using a change detector I know what is different compared to the polygon basemap, but now I need to take that result and check it against the text in the cad basemap and update it. for some reason the number of changes don’t seem to match when I compre the text. how would you suggest I attempt to do this, is there something I am missing.
