Comparing Geometry of Two File Geodatabases
  • September 13, 2016
  • 7 replies
  • 729 views
I would like to compare the geometry of two file geodatabase feature classes to locate spatial differences that I know exist based on the number of records of each and visual comparison (see highlighted linework). Is this something I can do using FME? I've tried using the both the ChangeDetector and Matcher transformers, however, neither of the results produce an output that specifically locates the differences. I'm only interested in 2D geometry changes and have not identified any attributes to match. I've also tried this FME model using other fc's that have a difference of 1 record but also get outputs that include many records, making it difficult to actually locate the issue
itay
Forum|alt.badge.img+17
As FME is very aware of spatial features, some pre-processing is usually needed before change detection.
So for example the use of the coordinaterounder on both inputs to bring them both to the same decimal precision.
Change detection remains a challenge and is not always as straight forward as it seems.
mark2atsafe
Forum|alt.badge.img+44
  • September 14, 2016
itay wrote:
The CoordinateRounder is usually only necessary when you are working with two formats, particularly when one format stores data as integers (eg shape) and the other uses floating point (eg dwg). The same format of data should produce the same results - even if it is to 15 decimal places - as long as the data is a proper match.
mark2atsafe
It's difficult to know exactly what is happening from a screenshot. It might be - as Itay suggests - that the two datasets have differing coordinate precisions and fixing that will solve the issue.
Really it's best to filter the data down to two features that you think should match, but don't.
Then examine those features in detail. You could write their coordinates out to a CSV or text file, for example, where it is easier to visually inspect them. Or you could look at the list of coordinates in the FME Data Inspector.
The order of coordinates is important; so a feature with coordinates a,b,c is not the same as one with coordinates c,b,a - even if they do visually appear to be identical.
A quick way to show whether FME sees a feature differently is to use a CRCCalculator transformer. That will give a checksum type value for a geometry. If the values for two geometries are different, then FME is seeing something different in the data. If the values are the same - but the ChangeDetector or Matcher don't register a difference - then something is going wrong in FME.
I hope this helps. If you can isolate a couple of features and post them here then we could be able to investigate in a little more depth for you.
mairesse
  • September 15, 2016
Another way to know which feature has changed is to extract the geometry of both data set after loading them with a "GeometryExtractor". The geometry is stored in an attribute "_geometry" by default. Then you can use a FeatureMerger in which you merge both data sets based on their "_geometry" attribute. You will then find the feature with a different geometry in the following output port: "NotMerged" and "Unreferenced". To get back the geometry, you can use a GeometryReplacer after the FeatureMerger.
See the attatchment for a visualization.
All the best,
Aurélien
  • September 4, 2018
mairesse wrote:
All the best,
Aurélien
When one is in SDE and the other source is in Fgdb, this method doesn't work. Any cool options like you mentioned or did I do something wrong?
xiaomengatsafe
Forum|alt.badge.img+3
Hi @josephjose, This is possibly due to the two format having different precisions. Have you considered Itay's idea of using a CoordinateRounder? Similar to the suggestion Mark2AtSafe mentioned, it's recommenced to examine two features that appear to be a match visually, but not reported as matches using the above method. This should give you clues as to where the differences are, and whether they are actual geometry differences, or only differences in coordinate precision.
revesz
Forum|alt.badge.img+15
  • September 5, 2018
AnchoredSnapper may also help by setting the tolerance to a very short distance (eg 1m or 10 cm).
