Compare and filter out line with shorter length
  • Jan 14, 2016 3:48 PM UTC
  • 192 views
I have duplicate line segments with same unique ID but different lengths. I would like to filter out the shorter line and keep the longer line for further transformation.
Best answer by jdh
Calculate the length, sort your features by length and then use a sampler (First 1 feature), grouped on the Unique ID attribute. The longest lines will be from the sampled port, and the shorter duplicate lines will be sent through the unsampled port.
Alternately use a DuplicateRemover in place of the Sampler.
jdh
Forum|alt.badge.img+41
  • Jan 14, 2016 3:55 PM UTC
Forum|alt.badge.img+54
  • Jan 14, 2016 3:56 PM UTC
If you sort by unique ID and length in desc order then use a duplicate remover, FME will output the longer line via the unique port.
  • Jan 14, 2016 4:06 PM UTC
Thank you !!
Thank you.
