Combining closed curves with polylines
  • May 31, 2023 10:57 PM UTC
  • 22 views
kdwss
Forum|alt.badge.img+3
I'm trying to combine the two pink polylines with the green closed curve and make them one entity without making an aggregate. They are for use in AutoCAD and can't be aggregates as they show up as a block and not a polyline. LineCombiner does not work.image
DanAtSafe
Forum|alt.badge.img+23
  • Jun 1, 2023 11:46 PM UTC
Hi @kdwss​ Should the result be a single self-intersecting line like this:
image where vertices 1 & 4 are the same?
